DoraDobtka: Launch hotkey depending on user/role
Please help me solve the problem by improving it.
It is necessary that the same key (for example, "F3" - creating a new order) launches different actions depending on users and/or roles. For example, there is a chain of stores and each store has its own separate BP, and each manager knows that when pressing F3, a new order is created. Now each store has a separate hot key for creating a new order.
Good day. In theory, this can be solved without any modifications. Create one process with one status, in which this process will be created, and then depending on the author (he obviously has a store in his role or somewhere else, where he works, registered) and by this parameter, you can change the BP for this order.
27.02.2025, 16:42
let him cook
OneBox production wrote:
good afternoon In theory, this can be solved without refinement. Create one process with one status, in which this process will be created, and then it depends on the author (he clearly has a role or somewhere else the store where he works is registered) and you can change the BP for this order based on this parameter.
Good day!
Thanks for the answer, but at the moment, this option is not suitable, because you need to open two different BPs with one key.
27.02.2025, 19:50
Yurchenko Roman Sergeevich wrote:
because one key needs to open two different power supplies
I don't see any contradictions yet. Why can't my solution switch the "Quick Creation" BP to "Store BP 1" or "Store BP 2" depending on the author?
05.03.2025, 12:12
