How to specify a name in multiple languages ​​in an additional process field
Multilingualism enabled
Two languages ​​are used:
- Ukrainian
- Polish
It is required that the name of additional process fields is also available in both languages.
I looked through the additional fields in the settings and didn't understand where I need to specify the name in Polish. By default, all names are in Ukrainian.
I will share how to translate.
Look at the screenshots, write questions if you don't understand.
By the way, this is a lot of manual work and it would be interesting to speed it up.
Could you please tell me how this can be done?
Maybe you need to switch the language in the interface and change it to the desired language? Haven't tried?
10.02.2025, 09:16
Легеза Вячеслав iCOLOR OneBox
ФОП Легеза В.В.
Maksym Vadimovich Tyndyk
that's exactly what he did
the question is somewhat different
Legeza Vyacheslav
iCOLOR OneBox (FOP LEGEZA VIACHESLAV VALERIANOVYCH) wrote:
It's a lot of manual work and it would be interesting to speed it up.
so it would be interesting to speed up manual work
How can this be implemented?
10.02.2025, 09:21
Legeza Vyacheslav
and what are the suggestions?
11.02.2025, 09:57
ФОП Легеза В.В.
Legeza Vyacheslav
the goal is to minimize translation time while minimizing the budget
What are the implementation options to get the desired translation result?
12.02.2025, 09:52
ФОП Легеза В.В.
Legeza Vyacheslav
Please, as a developer, suggest possible solutions so that the most suitable one can be chosen.
19.03.2025, 16:55
