Mobile app
Good afternoon!
To install a mobile application, you need to open the Google Play Store or the App Store (depending on which platform your mobile device is on). In the search bar, type OneBox and select our application after the search is over. Next, click install and within a minute (it all depends on your Internet connection - on average it takes 15-20 seconds) the application will be installed on your device.
12.08.2020, 16:39
«Один юрист із портфелем у руках награбує більше, ніж банда автоматників» Original comment available on version: ru
