It is necessary to implement synchronization according to the directory with Ukrainian. and Russian languages
Boxing https://chekhol.com.ua
It is necessary to add an item for Ukrainian in editing the filter. reference version https://take.ms/6LQs8h
This is necessary so that when editing filters in the product card in Ukrainian or Russian, the filter value in another language is automatically substituted according to the directory.
IMPORTANT. If the values in the directory change, then for all goods they should also change for the Russian and Ukrainian versions.
How many hours do you need to implement?
Good afternoon. We do not support the mvp version, so we will not modify anything there.
13.03.2023, 17:33
you can configure via the action Change product filter values to specified
or you can set up automatic transfers through another service
14.03.2023, 01:14
Ustimenko Igor
It is not entirely clear why we need this action if it directly changes one value to another. How to connect fields with Ukrainian. field in the directory and substitute?
If possible, somehow explain in more detail what is meant and is it clear what the client ultimately needs?
17.03.2023, 00:19
