Links created through the Links app always open from both desktop and favorites in a new tab.
At the same time, all other applications open in the current tab, and it is possible to control opening in a new one using ctrl, cmd, or the context menu. When opening links created in Links, there is no such control; in Links, in fact, the main menu items used in the work, then there are a huge number of tabs.
An example of working in the system is a few minutes on the screen.
[file]18844[/file]
Links created through the Links app always open from both desktop and favorites in a new tab. At the same time, all other applications open in the current tab, and it is possible to control opening in a new one using ctrl, cmd, or the context menu. When opening links created in Links, there is no such control; in Links, in fact, the main menu items used in the work, then there are a huge number of tabs. An example of working in the system is a few minutes on the screen.
