Field Rate
https://crm.dobavki.ua/
Before the update on the OS, in the settings tab in the Contact there was a Rate field (for calculating the RFP)
After the update, this field is gone. But the actions that consider the RFP "Create a payroll business process based on business processes closed by an employee for the past month" still take the value that was recorded in the Rate field. There is no field, but it still counts by value from that field
Tell me where this field is now or how to fill it out
These fields cannot be filled in anywhere. In the action settings, it is possible to specify from which additional user field to take a bet, use this
10.08.2022, 18:06
