Improvements for a personal account
1. Here https://univer.1b.app/admin/shop/boxclient/12/interface/?groupid=5 in the "Products" block (Fig. 1) display such items (Fig. 2 )
If the checkbox is enabled and a bp with a stage is selected, then do not add the product to the cart, but immediately create a process in the personal account and transfer the client there with the addition of this product with the quantity that he chose in the list of products.
2. Here (Figure 3) add a block so that you can rename this header in the settings.
3. And give the opportunity to rename the button "At cats" (Fig. 4) in the settings.
Please rate each item.
1. I.e. do not add to the cart but add to the cart and immediately create an order with this cart in the selected status? 3h
2. 1h
3. 1h
05.07.2022, 13:53
anonymous hamster
2. 1h
3. 1h
OK. Set up an invoice pliz as in this task https://1b.app/ru/forum/other/13895-deavtorizatsiya-klientov-v-lichnom-kabinete/ on FOP Litvinov.
Thank you.
05.07.2022, 17:39
Improved 3 settings in the "Products" block. Here's what happens when you click the add to cart button with enabled. If you need to somehow correct the text, write.
10.07.2022, 19:29
Good afternoon, thank you, we tested everything ok, the only thing is that you need to transfer the client immediately to the created order. If possible, make it an option in the settings.
12.07.2022, 11:33
The link in the message as on the second screen does not fit?
12.07.2022, 11:47
Litvinov Alexey Nikolaevich
+ The client should immediately be thrown into the process, and not given a link.
12.07.2022, 11:54
anonymous hamster
Nope(
12.07.2022, 11:55
Well, you knew right away that you needed it that way, why couldn’t you write it?) I’ll do it
12.07.2022, 11:55
anonymous hamster
Dyakuyu.
maybe I just wrote it not so directly (Fig. 1), but I meant it)
12.07.2022, 12:37
checked, it works. Thanks
13.07.2022, 10:57
