Rate the box
below, you can select the fields, for which you can follow the process: https://take.ms/4EU78
26.01.2022, 12:55
Igor, did the above solution help you?
26.01.2022, 15:28
Dydyk Ihor
ПП
I protest different options and sign. Dyakuyu!
26.01.2022, 16:05
Dydyk Ihor
ПП
Yarina
It's a pity it doesn't work for watering type "date and hour".
27.01.2022, 12:41
Please specify the error with an example (link) to the process/setting
27.01.2022, 16:32
Dydyk Ihor
ПП
BP - https://box.esmile.com.ua/admin/customorder/oplati/96729/edit/ go to the "Result" stage
28.01.2022, 10:44
Dydyk Ihor
ПП
Check now.
Everything seems to be O.K.
31.01.2022, 09:35
