Form a process by balances - not all processes are formed at the beginning of the accounting period
Made revision https://box.webproduction.ua/2015809087/
Action configured https://take.ms/bNstP
Process /admin/customorder/protsesi-skladu/726/edit/
One process was created normally on 1.11, and for some reason the second one was created on 2.11 https://take.ms/Qe7Ax
As a result, incorrect calculations are obtained. The action runs every hour and it seems like it should have worked in a day, but the process was not created
check by date fixed, on the first day an extra process will not be created
05.11.2021, 17:27
OneBox Corp - Інтегратор
Maria
OneBox production
so it is the first one and should be created, this is the day of the beginning of the period. The problem is that on the 2nd the process was created and not the first, that is, the one that was created on the 2nd should not be
05.11.2021, 17:34
Sukhanitsky Andrey
Integrator
no, on the contrary, the first number should not have created a process. Because quote from TK: "On the next day after the ordered, it is necessary to create a new process."
05.11.2021, 17:46
Maria
OneBox production
Then it should be the End Day of the period, I put 1, just because it says Start Day of the period
05.11.2021, 17:48
If I put 31, will it create the 1st?
05.11.2021, 17:50
OK
05.11.2021, 18:01
