Filter in products by default
There is a filter https://box.terem.com.ua/admin/shop/products/filters/744/control/
I checked the box "Default for all products" created a new product https://box.terem.com.ua/admin/shop/products/4487/filters/
And there is no such filter, it is not set by default.
What is the problem? It is necessary for me that the filter was put down in all products.
Hello.
This setting works when saving the filter block in the product or when saving the product filters in the tab. It just won't work when creating/updating a product.
09.09.2020, 16:42
Korop Vladislav Pavlovich
Employee wrote:
There is a filter https://box.terem.com.ua/admin/shop/products/filters/744/control/ I checked the "Default for all products" box and created a new product https://box.terem.com.ua /admin/shop/products/4487/filters/And this filter is not there, it was not set by default. What's the problem? It is necessary for me that the filter was put down in all products.
You need to specify a default filter in the category, then when creating a product, the filter will be automatically added to a new product, but without the value https://prnt.sc/uecetj
09.09.2020, 17:38
Bodyako Dmitry
Employee wrote:
Hello. This setting works when saving the filter block in the product or when saving the product filters in the tab. It just won't work when creating/updating a product.
"In the taba" meant the filters tab? If yes, then I tried that, I pressed save - the filter did not appear https://prnt.sc/ueci53
09.09.2020, 17:43
Try to go there right away on a new product. They should appear, but they will be empty.
09.09.2020, 21:53
Bodyako Dmitry
Created 1 more new product https://box.terem.com.ua/admin/shop/products/4489/filters/
I immediately went in - there is nothing, I pressed save - it did not help
09.09.2020, 21:56
It looks like a mistake, but I can't say for sure - I can't get on the server. Throw me a simple private task in the ssh box to the server - I'll look and tell you exactly what's wrong / correct
10.09.2020, 11:01
Korop Vladislav Pavlovich Employee wrote:
Bodyako DmitrySotrudnik wrote / a: Try to go there right away on a new product. They should appear, but they will be empty. I created 1 more new product https://box.terem.com.ua/admin/shop/products/4489/filters/ I went in right away - I didn’t have anything, I pressed save - it didn’t help
Do as I tell you. Go to the settings of the category in which you are creating the product and select the default filter https://prnt.sc/uecetj , after which it will automatically appear when creating the product
10.09.2020, 11:10
Kachanovsky Andrey Vladimirovich
Client wrote:
Korop Vladislav Pavlovich The employee wrote / a: Bodyako Dmitry The employee wrote / a: Try to go there right away on a new product. They should appear, but they will be empty. I created 1 more new product https://box.terem.com.ua/admin/shop/products/4489/filters/ I went in right away - I didn’t have anything, I pressed save - it didn’t help Do as I tell you. Go to the settings of the category in which you are creating the product and select the default filter https://prnt.sc/uecetj , after which it will automatically appear when creating the product
I need it without being tied to a category, because they will be loaded automatically, exactly with the setting that I specified.
10.09.2020, 11:11
If the product does not have a category selected, there were problems. Corrected.
11.09.2020, 14:03
