sometimes the order amount from the variable pulls with thousandths in the format 123.0000 instead of 123
- it was noticed that sometimes the order amount from the variable pulls with thousandths in the format 123.0000 instead of 123 , this leads to sending 2 sms instead of 1 and often customers do not correctly understand the amount.
You can specify the number of digits after komi in square arms in the middle of the change, for example {|$ordersum[#0]|} - means that the number of the "sum of the process" will be rounded to tsіlih
09.09.2021, 13:01
Yarina
Dyakuyu! I'm just wondering why in 90% of cases the system generates a round sum, and in 10% it prescribes a comma and zeros. didn't see the pattern.
09.09.2021, 14:46
and another problem is that {|$ordersum[#0]|} is formed only in the data array, and separately the [ordersum] variable behaves differently for some reason
09.09.2021, 17:26
Zubarev Sergey
Optium
here, perhaps, the programmers can give advice.
Zubarev Sergey
Optium
because of the different types of change. the curly temples are exactly right.
10.09.2021, 10:35
Sergey, did Yarina's solution solve your problem?
If yes, you can mark the correct answer.
10.09.2021, 17:09
no output of {|$ordersum[#0]|} variable in sms caused process to crash - this variable does not work in sms , reverted to [ordersum]. but it is still not clear why in the same stages of the process the variable is formed differently.
10.09.2021, 19:57
in Smarty, you can use the number_format modifier, which sets the format for displaying the date
you can try the variable {|$ordersum|number_format:0|} (this is if rounded to integers), or {|$ordersum|number_format:2:".":","|} (2 decimal places, decimal separated by a dot, and thousands - a comma)
13.09.2021, 16:26
OneBox production
your solution is working, thanks.
17.09.2021, 10:33
