The user has lost access to the document templates, before everything worked in the rights, nothing was changed and there is access everywhere
Good day Check the access rights Templates -> Document templates
And the page will become available to the employee
10.12.2024, 11:19
Андрій
CEO, owwa.com.ua
I don't understand where exactly to turn it on, explain where it is turned on (reference is preferred). Everything worked before, but since templates are not often corrected, now they noticed that it stopped.
If you are talking about the template collection, access is enabled there, I am attaching a screenshot.
10.12.2024, 13:44
You need to go to access rights using the link you provided below and click the Configure button
In the window, tick what exactly to allow editing https://prnt.sc/K_-G0l-fZ6Kq
10.12.2024, 13:55
Андрій
CEO, owwa.com.ua
Thanks, now it works! Tell me if there is a plan to restore the changelog, because there are new settings being implemented, but no one knows about them.
10.12.2024, 13:58
