The cost of implementing a CRM system
sent the offer in private messages
04.11.2024, 16:15
Good afternoon, I have the same question, how much does it cost to implement this CRM system for a small business?
14.11.2024, 12:40
Назарій
Hello!
I can share my experience — we implemented CRM in a small logistics startup, where about 10 people worked. The cost depends heavily on the tasks: if you only need a customer base and simple automation, you can fit into a reasonable budget. For example, we started with a basic tariff, and then gradually increased the functionality — reporting, funnels, integrations.
The key point is to find a system that really solves business problems, and not just "looks good". It's like in the technical field: you can buy anything, but if you need a really reliable solution, they look for Ford automatic transmission parts https://akpp-beretta.com/ru/kataloh-tovariv/ford from trusted suppliers. The same with CRM - it's better to focus on those who know their business.
We chose a system where support helped us set everything up for our processes - and since then it has become a real working tool, and not just “another program”.
I hope this helps you with your choice!
03.08.2025, 04:05
Nazariy wrote:
Greetings!
I can share my experience – we implemented CRM in a small logistics startup, where about 10 people worked. The cost depends on the tasks: if you only need a customer base and simple automation, you can fit it into a reasonable budget. For example, we started with a basic tariff, and then gradually increased the functionality – reporting, breakdowns, integration.
The key point is to find a system that really solves business problems, and not just "looks good". It's like in the technical field: you can buy anything, but if you need a really reliable solution, look for Ford automatic transmission spare parts https://akpp-beretta.com/ru/kataloh-tovariv/ford from trusted suppliers. So with CRM, it's better to focus on those who know their stuff.
We chose a system where support helped us customize everything to our processes — and since then it has become a real working tool, not just another program.
spam)
04.08.2025, 16:54
