Development version of the instance
I want to make a copy of our current instance (company) with all processes and data for a test environment to implement new modules and then transfer to production
From experience I can say that transferring changes from one box to another is very problematic. Specify what exactly you want to do and test that needs to be transferred to a separate system?
10.07.2025, 12:46
Сергій
There is already a configured box that is used for business.
it includes (workflows, contacts, warehouse, accounting)
I would like to make a copy of this box and make integrations on it that I could test, give to employees (quality testers) to test, and only then transfer it all to the production box. Ideally, it would be cool to get access to deploy such environments on demand in order to synchronize data and update them.
10.07.2025, 14:47
Any integration can be tested on a combat box. Any new BP or contact interface can be tested on a combat box. Describe in more detail what you want to do that you are afraid of breaking the combat box, that you needed a test environment for this? A specific example.
Sergey wrote:
How to synchronize data
This is exactly what is not possible. The systems will each live their own life and you will not be able to merge them.
10.07.2025, 16:00
you can make a copy
but the question is how often should it be updated? because after some time the test environment will lose its relevance
and yes, a copy is not a problem., contact your manager if there is one, or indicate which system you are talking about.
11.07.2025, 15:49
