What are the payment terms for expanding OneBox space to 10TB?
Questions on this topic:
https://1b.app/ua/forum/onebox-official-news/16126-mesto-na-diske-dlya-oblachnih...
What are the payment terms for expanding to 10TB when the number of licenses exceeds 21 workstations and the amount of data becomes greater than 360GB?
currently the cost is $1040 per month (it all depends on the hoster's rates and they change) for 10TB
if you need +100GB - then +100GB is more profitable
if you need 1TB, then the licenses will probably be more profitable
you need to calculate in the process how much you need specifically
18.03.2025, 11:27
Легеза Вячеслав iCOLOR OneBox
ФОП Легеза В.В.
Chyzhyk Oleksandr Serhiyovych
An example is this:
A manufacturing client has 25 users
According to your official terms, it has access to a volume of up to 360GB inclusive.
But his data usage at the end of the billing period exceeded this limit and amounted to 393GB.
At the same time, the volume growth is from 7 to 10% monthly.
That is, next month the expected volume at the end of the billing period may be from 420 to 432GB
The only thing that looks realistic now is that it needs to offer expansion within the possible 10TB.
But what conditions could there be?
As I see it, the possible options are:
Option 1: develop some simple calculation algorithm
Option 2: remove the 360GB limit
Option 3: Change the limit according to your spending
As a partner, I need to clearly understand the terms so that the Client understands and plans for their possible costs.
First of all, the issue concerns production facilities where data is actively accumulated that must remain in the system, and this largely depends on the complexity of the production itself.
18.03.2025, 18:48
