Problem with label printing
The next problem is after the update, after clicking on the button to credit https://box.vals.net.ua/admin/customorder/issue/14145/edit/ labels should come out, only one 100 pieces come out.
7.5 labels should come out. 100 pieces each and the last, broken down into 43 pieces.
Please correct.
You can view?
Printed labels do not work.
In progress https://box.vals.net.ua/admin/customorder/issue/14194/edit/
Should come out:
3 labels
with quantities of 100 pcs 2 labels and 1 label with a quantity of 35 pcs.
10.12.2020, 17:59
Krasnobrizhev Alexander Viktorovich
Please correct.
Good afternoon, please tell me at what stage and what actions are configured to make it work. It is advisable to immediately give links to setting up actions. Thanks
14.12.2020, 13:23
14.12.2020, 15:22
Sorry, but I can't afford to look at 85 actions to understand how your bp is configured and why some of the 85 actions do not work the way you want. Can you put into a separate procedure one specific action that, in your opinion, works wrong and indicate what exactly is wrong in it?
16.12.2020, 18:04
As far as I can see, all documents are formed. Here you can see https://box.vals.net.ua/admin/customorder/issue/14145/document/ (just 7 by 100 and 1 by 43)
Perhaps the problem is that before they all opened on one page at once, but now only 1 opens?
17.12.2020, 12:57
there are 2 options here:
1. The browser began to forbid you to open several tabs at once
2. The action can only open 1 tab
most likely the second. Try other browsers and enable all permissions for them on the site.
17.12.2020, 13:11
1. Do you understand that I will not change the browser?
2. Do you understand that this happened after your update?
3. Solve the issue, think about how to make it work, and do not unsubscribe the raw text.
17.12.2020, 13:14
Bodyako Dmitry
17.12.2020, 13:38
enabled, does not help, any other suggestions?
17.12.2020, 14:13
aha, give the link to process with the configured procedure at transition to which at me tabs will open.
17.12.2020, 14:20
And please tell me what permissions and where specifically in the browser for the site you have enabled
17.12.2020, 14:20
I don't understand what to do there to open the documents. How can I FAST detect the problem? What to do?
17.12.2020, 17:44
link to the process https://box.vals.net.ua/admin/customorder/issue/14145/edit/
you need to go to the stage Re-generation of labels.
there are not several tabs opened, but one with all the documents at once.
It seems to me that the Write document action began to work differently, and specifically this function
18.12.2020, 08:52
Hello, fixed the problem https://prnt.sc/w5gju0
18.12.2020, 16:56
To close the task, on the left next to my answer there is a checkmark when you click on which you mark the answer as correct.
11.01.2021, 18:12
