There is a need to save the generated documents in .doc format, but when saving, a number of limitations were identified:
-the image https://i.imgur.com/gaxLaYs.png is not displayed, only the variable row product image is interpreted
-text formatting, font size, spacing and indentation between paragraphs, takes off https://i.imgur.com/F8gY03D.png
-page break configured in the code does not work.
Tell me where I can find documentation on the rules for converting documents to .doc format
There is a need to save the generated documents in .doc format, but when saving, a number of limitations were identified: -the image https://i.imgur.com/gaxLaYs.png is not displayed, only the variable row product image is interpreted -text formatting, font size, spacing and indentation between paragraphs, takes off https://i.imgur.com/F8gY03D.png -page break configured in the code does not work. Tell me where I can find documentation on the rules for converting documents to .doc format
Hello! This is a very common problem when working with document formats. Regarding displaying images and preserving correct formatting, it is worth paying attention to how your system converts files to .doc format. There are certain limitations in the system itself regarding image and style support. To solve this problem, I recommend contacting your system's documentation or support service, as they may provide specific recommendations on preserving formatting and working with images. Some systems have specific data processing features, so it is worth clarifying these points.
