Podtіbno real_zuvadі Dіyu at the stage Yaka will be in the process of pіdrakhovuvati kіlkіst commodіv (Vіdfіlіtrovanіkh іn additional field) in the sum і add (chi vіdnіmatі) up to the number from the directory і write in the field of the directory
Part of the implementation
For the help of what is in the system
Butt
Order https://rovo.org.ua/admin/customorder/order/982368/edit/
Goods with fields such as filtering ()
Directory https://rovo.org.ua/admin/shop/custom/object/directory/6/
Diya yaka already є https://rovo.org.ua/admin/shop/workflow/8/procedure/112/?status=0
Mіnus cієї dії scho won't write down є tіlki z the rest of the goods, but you need to add all the positions.
May 7 be seen before it is added to the directory
I think it will be correct to do "Add process products to / from the directory (a)"
After passing the skin position of the goods in the process product fields.
Such a way in product automation [file]
І formulas
Add more skin care products to add. poly
05.04.2021, 10:41
Unfortunately, your description is more like reasoning, from which it is difficult to single out the main essence - what needs to be finalized.
Please specify exactly what and where you need to modify for miscalculations.
06.04.2021, 16:50
It will be correct to do "Add process products to / from directory(s)" https://crm-onebox.com/en/ajax/download/4857/
1, After passing the skin position of the goods in the process Add the function of updating additional. product fields from reference.1
2, I formula
Add more skin care products to add. fields https://crm-onebox.com/ru/ajax/download/4867/
Is it so sensible?
07.04.2021, 08:50
Duck, you can already update the product fields with this action in the opposite direction if you add (find products and update values)
Well, or I just don’t understand how and which fields you want to update after passing to the directory - perhaps provide an example
2, I formula
Move the action to the editing procedure - does not solve your need?
08.04.2021, 17:29
1, After passing the SKIN POSITION OF THE GOODS IN THE PROCESS (not important) Add the function of updating additional. product fields from reference.1
BUTT
by position (Look at the screen) 1 and 2 all the rules
by position (Seen in the screen) 3, 4 and 5 positions different and an additional field (Shown in GREEN) one (according to the new mi filter)
Pidrahunok povinin buti for extra. field (Seen chervonim)
we write down the data from the reference book in the field until the end we add the quantity (from the quantity of the goods in the process)
and write in the directory
When passing the offensive position, repeat
Position No. 3 (quantity of goods in process 2+ (additional field (Vid_leno chervonim) (-3)) is written in the reference book =1)
Position No. 4 (quantity of goods in process 3+ (additional field (Vidileno chervonim) Vityaguєm from the directory (Filter (Vidileno GREEN) )(1)) write in the directory =4)
Position No. 5 (quantity of goods in process 2+ (additional field (Seen red name) Vityaguєm from the directory (Filter (Vidileno GREEN) )(4)) write to the directory =6)
2, I formula
it is not necessary to blame the procedure.
Describing more yak povino shield
3/4 of what has already been described is already implemented
Є
DIA №1
(Fill in an additional field based on additional fields and reference data)
https://crm-onebox.com/en/ajax/download/4858/
-- yak vityaguє data from the reference book in the add. field
DIA №2
(Calculate and write value to additional field if conditions are met)
-- Yaka pіdrakhovuє danny kіlkostі goodsіv i add. watering
DIA №3
("Add process products to/from lookup(s)")
-- how to add data to the directory
Ale vona їх adding є pіlya prohldzhennya all sієї tablesі tovarіv і danі tіlki on the remaining product will be recorded in the directory
No. 4 CІ DІЇ it is necessary to group into one in such a sequence and spratsvuvat may WHEN PASSING THE LEATHER GOODS in order
09.04.2021, 09:27
It probably dawned on me - you need to perform the logic of 3 actions in turn for each product of the process.
This can be done only by partially combining the necessary logic from 3 actions into 1, so that 3 logics are executed inside the enumeration of the process products.
The development of such an action will take about 10 hours.
09.04.2021, 16:56
why so expensive?
if you have є їх tre just combine into one and put Okremo for the skin product.
TRANSFER QINU
09.04.2021, 21:09
why so expensive?
TRANSFER QINU
I don't think I'm obligated to justify the stated amount of time needed for revision. Just as we have no obligation to carry out any of the improvements from the client to the product.
If you don't like it, that's your right. You can either agree or not, or find other performers - the product (box) is yours and you can do whatever you want in it.
12.04.2021, 16:57
