OS - filters work incorrectly / shift chart generation
1. Go to the shift schedule generation section
2. By default, in the employees field, selects an authorized manager
3. When you try to remove or add a new manager for the filter - throws it on the main screen
4. When you try to specify a role - throws it on the main screen
