Contact coordinates are not deleted/corrected
What now?
This is how we enter the coordinates in the block of the contact card Location:
http://prntscr.com/nmtbw0
Wrong coordinates entered.
Can't reset or erase them.
Such changes are not saved.
You can only enter some other numbers.
It needs to be corrected so that:
- when entering zero coordinates, they were saved;
- if completely overwritten, a dummy is saved.
Add the ability to select a point on the map, and not just enter the coordinates or address in the fields.
24.05.2019, 15:56
