Problem іz nalashtuvannyam form
Есть необходимость работы с формами?
Мы специально разработали компонент для этого! Посмотреть компоненты
Task: to edit the form for filling in (contact data) for clients, from the completed form automatically transfer the data from the specified fields (for example: date of birth, become\type of client) in the client's card.
Solution: by creating the form with the specified fields (First name, Last name, Date of birth, Become\type)
Problem: (Fill in the data in) It is possible to choose the system values of First Name, Last Name, however, the system values of the date of nationality cannot become.
What is the ability to add the required system values in "Fill in data in"? I’ll understand the same in terms of importance with such meanings as First Name and Last Name.
Good afternoon
adding these fields will take 1 hour
you can make additional fields like this and then use the action to copy the data from them to the base fields - if this crutch solution suits you, then you can configure it without modifications
30.05.2021, 20:17
