Correct the robot "Change the contact group depending on the value of the fields" (Ignore the empty field)
Є client with an empty field "Client status" and can only be used with an empty field "Group".
In the settings for automation for contacts (when saving) https://box.e-zoo.com.ua/admin/users/action/update/edit/, the option "Change contact group depending on the value of the fields" has been set If you can't wait, you can use the option "Remove from the specified group if the conditions are not met", because the empty field does not return "New client".
Judging from the logic of the action, the selected group should be deleted.
Provide a link to the problem contact to analyze if there is a problem.
13.05.2021, 16:55
Перегіняк Олександр
Oneboxconsulting (интегратор)
https://box.e-zoo.com.ua/admin/shop/users/52603/
Diya bula was fixed quite a long time ago and worked correctly earlier.
13.05.2021, 17:57
