Good afternoon
Earlier on the forum, a question was asked about deleting phone numbers from companies due to incorrect filling of the database. https://crm-onebox.com/ru/support/contacts/8475-vigruzka-kontaktov/
Improvement is required for this block: deleting contact numbers of companies that were created using restapi
Good afternoon Earlier on the forum, a question was asked about deleting phone numbers from companies due to incorrect filling of the database. https://crm-onebox.com/ru/support/contacts/8475-vigruzka-kontaktov/ Improvement is required for this block: deleting contact numbers of companies that were created using restapi
Good afternoon. Perhaps you meant this task? https://crm-onebox.com/ru/support/contacts/8192-udalenie-vseh-telefonov-kompaniy/ in it you were offered a revision.
ps questions are written off automatically.
The questions are related, but the essence is the same)) An action is required that allows you to delete all contact numbers of companies created by the restapi method, you can immediately account
I think this is a bad idea. In some cases, it will not be clear exactly how you created the contact. Looking at the history is not 100% providing a solution to the problem. Can you somehow filter users in the list of users who need to delete phone numbers? It is possible to make for example a field in the panel of mass changes. You filter the contacts you need, click on the "delete phones" checkbox, and all filtered contacts will have their phone numbers deleted.
In addition, there is a skin of contacts without the Creator and creation through restapi, you need to delete the latter directly If it is possible to filter directly by them, the method you suggest is suitable
[file]5527[/file]
https://crm.lappukraine.com/admin/shop/users/?filtercreatorid=1&filtercustomEstv1s=&filterlegal=&filtercity=&filterregion=&filtermanagerid=&filtercustomRegionalniymanagerid=&groupid=0&filtercustomRegionklienta=&filtercustomZona=¬ordertype=&filtertypesex=&filtercompany=&page= you can filter the ones you need like this contacts. Ok, let's make it possible to delete numbers from filtered contacts in the bulk changes panel. Takes 1 hour. I issue an invoice
Good afternoon. /admin/shop/user/masschange/block/ the "Delete all phone numbers" block appeared here. Add it, select the contacts you need and choose to delete phones in the block
Sunny weather I'll be back soon wrote: Good afternoon. /admin/shop/user/masschange/block/ the "Delete all phone numbers" block appeared here. Add it, select the contacts you need and choose to delete phones in the block
Attached are the screenshots of the panel, this block is not present
Sunny weather
[file]5670[/file]
[file]5671[/file]
