Here are our contacts in List view:
https://dimsp.crm-onebox.com/admin/shop/users/
The table header is displayed as we configured
[file]2349[/file]
We impose ANY filter, for example, by a group of contacts
https://dimsp.crm-onebox.com/admin/shop/users/?groupid=14
e.g. by contact group
the table header changes, although it should remain
[file]2350[/file]
same. configured on the first screen
A big request to correct or explain,
where the wrong setting has been made.
Explanations of the type will look very strange:
"That's how it works for us"
same. configured on the first screen A big request to correct or explain, where the wrong setting has been made. Explanations of the type will look very strange: "That's how it works for us" :)
Hello. For each group, you can customize your interface, as well as for the combination of filtered bp in the task list. The fact that you have different interfaces means that something filtered users by group, poked at the header, set your columns and saved the interface
Bodyako Dmitry Employee wrote: Hello. For each group, you can customize your interface, as well as for the combination of filtered bp in the task list. The fact that you have different interfaces means that something filtered users by group, poked at the header, set your columns and saved the interface
how to approve one interface for all contact groups, not to click individually for each one that has already been configured here https://dimsp.crm-onebox.com/admin/shop/users/ that is, so that under any filter applied to contacts, this table interface was displayed
Bodyako Dmitry
It is impossible to overwrite "in one fell swoop" for everyone. You can only try to filter the desired group and uncheck all columns so that nothing is displayed there. The idea is to take the standard interface
Bodyako Dmitry Employee wrote: It is impossible to overwrite "in one fell swoop" for everyone. You can only try to filter the desired group and uncheck all columns so that nothing is displayed there. The idea is to take the standard interface
nope, doesn't work like that
it turns out that there is no way to control this process now only change for filtered contacts? now it's kinda uncomfortable because it requires repeated action, to customize the display that is most convenient for all groups, which can be very many ... it would be ok to fix the changes we make to display the tables, for all variants of superimposed filters for example, to add a checkmark for this:
Bodyako Dmitry
nope,
[file]2385[/file]
[file]2386[/file]
Is it possible to put this useful function on investment, as a refinement in OneBox OS, to make it really comfortable to work there, not like now
Bodyako Dmitry
Employee wrote:
Yes, an appropriate option. Takes 2 hours.
not like now
