Is it possible to somehow improve the recognition by the box of clients who have the same phone, but sometimes they enter the country code, and sometimes not.
Now for boxing 380999999999 and 0999999999 are different clients. He needs to glue them automatically.
Is it possible to somehow improve the recognition by the box of clients who have the same phone, but sometimes they enter the country code, and sometimes not. Now for boxing 380999999999 and 0999999999 are different clients. He needs to glue them automatically.
you can use number auto-formatting so that all numbers are converted to the same format - /admin/shop/phone_auto_format/ either from 380хххххххх to 0ххххххххх, or vice versa - https://prnt.sc/vr9tep those. if you enter the number 380999999999 it will be reformatted to 0999999999
Yes, but it seems to me that when searching, it would be convenient to be able to search for any part of the number, and not a direct 100% match. By the way, the same applies to working with the "Search for duplicates" functionality.
thanks I'll try. As I understand it, now new applications will go correctly, but what to do with the old ones, is it possible to mass-glue old clients who have the same number?
Mulach Marina Anatolievna
