The data in the Address field is not saved.
actual address Moscow, Molodogvardeyskaya street
We fill in the field the city of Moscow, Molodogvardeyskaya street, click save, writes a save error is not specified Region. We indicate the region "Moscow", the data from the Region is automatically deleted and substituted in the city field. If we write the Moscow region, then the data from the City is automatically deleted and, accordingly, when saved, it already swears at the empty City field. How to be?
http://joxi.ru/Q2KPJKkTvOo3BA
http://joxi.ru/RmzJpPjCMvn7Qm
indicated the Moscow region, Khimki. saved. and after that it was already allowed to save without the Moscow region and change Khimki to Moscow
22.10.2020, 11:00
when changing any other field (for example, phone number), this error appears, although the address has already been filled in earlier. Three days ago, we initially had a problem entering the Address or changing the Address field. there was an error. The bug was fixed yesterday by updating the api map key. Now here is such a problem and an error in the Address field - the Region field is not filled.
http://joxi.ru/EA4y780hpX5E0r
22.10.2020, 12:03
remove the required fields in the address and there will be no problems
how addresses are delivered depends on Google
22.10.2020, 14:15
