Bulk Actions - Delete/Move Selected Contacts
Please tell me, is it possible to select contacts (when "contacts are listed") to delete or move several at once through a mass action to delete or move?
Going into the card of each contact to delete or move it is not very convenient!
Good afternoon!
Yes, of course - you can perform mass actions with contacts. Select the display as a list and open the right panel - you can perform the actions you specified in it.
15.10.2020, 18:26
«Один юрист із портфелем у руках награбує більше, ніж банда автоматників» Original comment available on version: ru
Perhaps the "select" checkboxes in the list view are disabled.
15.10.2020, 18:28
here is what you are interested in http://prntscr.com/uzywb5
15.10.2020, 18:29
Thank you!
15.10.2020, 18:33
