Error 500 when opening contact card
There is a contact card http://crm.mebelok.com/admin/shop/users/194455/
When I open it, it gives me a 500 error.
There is not enough 2Gb of memory to open the card.
13.10.2020, 14:32
Tasun Sergey Vladimirovich
and what loads open cards like that?
13.10.2020, 14:40
You probably looped parent/child companies.
13.10.2020, 14:59
Bodyako Dmitry
How can we fix this? We cannot do this from the interface.
13.10.2020, 15:51
You can. You need to go to the interface settings, remove the blocks that show you some tree of subsidiaries, tree obligations, etc. Then you go to the card itself. Then you need to find where you looped the parent / subsidiaries and fix the jamb.
13.10.2020, 16:01
