Automation for contacts
Is it possible to do automation to transfer a contact to a group depending on the product category?
Sergey, congratulations
In Contact Automation there is an action Change contact group depending on the value of the fields https://i.imgur.com/QC3UYSS.png
You only need to select a contact subfield in which to enter the required value, if there is a required product category in the process.
07.11.2023, 21:33
Лободзинский Сергій Витальевич
Susyak Igor
Integrator wrote:
Sergey, greetings
In Contact Automation there is an action Change contact group depending on the values ​​of the fields https://i.imgur.com/QC3UYSS.png
You only need to select some additional contact into which to enter the required value, if the process includes the desired product category.
I understand you, but there is no Product Category variable to enter it into the additional contact field
13.11.2023, 12:22
is of course
Choose exactly where you need to record - for example, in the Order at the Completed stage
add the action "Copy product field to additional process product field" and configure like this : https://i.imgur.com/y8fWuix.png
14.11.2023, 16:44
