Can't download contacts
Good day! Tell me how to correctly download contacts to an Excel table? I select all the contacts, click "send to", select "File storage", then "Export to file", then type "XLS" and click "Save". It says that the file should arrive in the mail, but nothing has arrived for the second day.
Andrew,
you did the right thing, try going to the Files app /app/files/ and downloading from there.
I recommend using the application "Import export contacts" https://1b.app/ua/app/exchange-contact/ - here you can choose which specific fields to export or import.
11.07.2023, 18:33
