Automation for contacts https://lab-service.1b.app/app/automatization-user/update/edit/ does not add the action Fill the contact card field when the conditions are met
When you click on it, nothing happens. Checked on different browsers.
More actions are being added. On other projects, the same action is added in automation.
Automation for contacts https://lab-service.1b.app/app/automatization-user/update/edit/ does not add the action Fill the contact card field when the conditions are met When you click on it, nothing happens. Checked on different browsers. More actions are being added. On other projects, the same action is added in automation.
