Formatting of 380 numbers was introduced
how to replace all existing contacts by performing this formatting, if mass actions with contacts do not make any changes, when you save only one contact, formatting works.
Захарюгин Юрий Олегович
also interested in such a question. I will listen
30.01.2023, 14:00
greeting
1) check whether autoformatting of phone numbers is configured correctly, you can specify at least three options when it is worth changing, for example:
2) indeed, with a mass change of goods, such automation does not work, but everything is ok when exporting-importing contacts: export at least ID+Phone and import with the indication of ID+columns with phone like this:
Be sure to check the report file in the mail after the update, it should be Updated: 1xx (the number of updated contacts)
all new numbers will be activated automatically.
01.02.2023, 01:17
yes, thank you, this option seems to work
02.02.2023, 16:08
