Lost ID numbers in contacts
Here https://univer.1b.app/app/contact/
https://take.ms/xfOUm ID jumped up a lot. There are not so many remote contacts that the ID person would jump like that.
Why did this happen and is it possible to correct and continue the list?
Tretyak Artur
Esteem about an autoincrement in tables and that happens at rollback of transaction with it.
06.01.2023, 22:50
Третяк Артур
bu
OneBox production wrote:
Tretyak Artur
Nice, I appreciate it. It turns out the database tables are shakalim?)))))
Well, as I understand it, everything is ok and there are no troubles. Thank you.
10.01.2023, 14:40
Tretyak Artur
jackalim
I don't know what you put into this word))
in short, you create contacts and then, due to some kind of error, you roll back the created contacts. This may be due to automating a contact or when creating an order, when a client was created, but when switching to the status, some action threw an error and the contact was rolled back. If the jumps are not frequent and not for long periods, you don’t have to worry, there are enough IDs for everyone. If a couple of lyams at a time and often, it’s worth looking for who and where rolls back the creation of a contact, otherwise the IDs will end and you will need to do something about it.
10.01.2023, 15:01
Третяк Артур
bu
Tretyak Artur
jackalim
It means that the bd is jacking)))
Thank you, we will look at what stage it jumps, because the 5th million has already gone)
10.01.2023, 20:16
