The list of positions can be viewed in the structure.
You need to add it to the menu
https://prnt.sc/uocukwLooks like this
https://prnt.sc/uocutyYou can open positions by speaking
https://prnt.sc/uocv0cBut the bottom line is that only posts of the structure
https://prnt.sc/uocv9x (which are created in the structure) are displayed there
Also:
1) You can add any position to any contact
2) When adding a position, if it is not there, then it is added to the general directory, which cannot be edited, you just have all the positions stored there.
3) In order for employees to be displayed in the structure, you need to register them with the same job title as written in the structure, and there must also be a check mark in the "Employee" contact card
You can make a drop-down list, but it will be a refinement. Now it works in this way - when you write the first few characters in the field, then you immediately display the positions that are suitable for the title and you select them from the list, that is, almost the same as the drop-down list, so I don’t think it’s necessary to do the revision
