https://rivcont.info/2696141/
Event https://rivcont.info/app/event/851137/ by number 0985039362
We tie up the phone to the client in the process https://rivcont.info/app/contact/230200/
The client has two phones
Go to customer events
Event 851137 did not pull up https://rivcont.info/app/event/?dumpHash=app-object-dump-d772ff7f5b5fc290faab3fd22e6f2577&noFilter=1&objectsFromName=Makushova%20Klena
Due to this problem, we cannot correctly use the action on the "Check for a call to the client" stage, because clients often call back from other numbers.
See what's the problem
Ustimenko Igor OneBox production OneBox CTO wrote: event formatting (detection of contacts) - it is done like once an hour and not immediately
Due to this problem, we cannot correctly use the action on the "Check for a call to the client" stage, because clients often call back from other numbers. Can we think of something so that the new numbers are also taken into account by the action?
Ustimenko Igor
OneBox production
yes, you can add more search logic there 2h
Vysokos Nikolai Aleksandrovich wrote:
Ustimenko Igor
OneBox production
2h
