Search problem Company name in contact card
Problem:
In the Company field, in the contact card, the search does not work.
What they were doing:
1. Renamed the type Company to Legal entity.
2. Removed a man and a woman and added an Individual.
3. After the MVP update, the types of company, man and woman were added again.
3. We thought that we should use the new type 'company' and removed the Legal Entity.
Help return the settings so that the search for the company works. But ideally, it is better to make a drop-down list with the ability to filter by counterparties/contacts. Then there will be no such error in principle.
This problem arose due to the fact that you had an old version of php on the server
I updated it and the problem is solved. But in fact, this is already a server setup
14.09.2020, 12:07
Thanks
So hetzner had to update something?
14.09.2020, 12:28
Michael
Client wrote:
Thank youSo hetzner had to update something?
No they don't serve your server
you had to hire a specialist from outside or pay 1 hour for the setup that I already did.
14.09.2020, 12:30
Now it is clear.
And somewhere it is mentioned in Boxing that the version has increased - update the system, php, what else and all that?
Our will receive such notifications, then we will ask our specialist next time.
14.09.2020, 12:41
Yes, this can be seen in the server load panel (there is such an application in the market)
there you can see the version of the software on the server and shows whether it is up to date
14.09.2020, 13:41
