Access to process status
It is necessary to completely close the manager's access to the status of the process.
How to do it? If you just uncheck the status box, then the manager still sees the statuses of the processes where he is the author
for the employee to have access to processes where he is the author, responsible and observer, the smart ACL setting, which is enabled by default, is responsible
smart ACL is author/responsible/observer
By default, when it is enabled, access is granted if the contact is the author/responsible/observer, regardless of whether he has access to this BP.
If you turn off smart ACL - then access will be strictly according to access rights. those. the employee will see only those processes to which they have access according to the rights.
14.09.2020, 10:43
Thanks
And how to turn it off?
14.09.2020, 10:46
Krilyuk Roman wrote:
Thanks, how do I turn it off?
developers can do it
14.09.2020, 10:47
