OS: Unable to export contacts
box allar.crm-onebox.com
installed the app "import-export of contacts"
I select contacts and try to transfer them to this app - nothing is displayed: https://take.ms/vzw2c
in addition, when I click "select all", it selects only 50 contacts, although there are much more. visible on the screen.
fix please
Selected contacts can be exported. Try to reset the browser cache if you have an empty window
15.10.2021, 16:49
great, it works. and how to choose 3 thousand contacts?
16.10.2021, 17:03
you can filter the contacts you need by using the filter panel on the left, and when selecting the contact check mark from the top, click on the button - select on all pages, then all filtered contacts will be exported
18.10.2021, 09:30
thank you, but I didn't even notice the elephant ????
18.10.2021, 10:42
