Good day.
Implemented integration with corporate mail server.
The settings are the same, both for IMAP and for SMTP.
Input leaves are transferred to the system, output - not.
In the vine come:
[2021-07-26 18:13:06]
point: /var/www/newalphademocrm/web1/web/cron/cron-minute.php
data: Array
[login] => r.kotsiubynskyi@box.astelitgroup.com
[status] => error
[message] => Connect SMTP is Fail
https://astelitgroup.crm-onebox.com/admin/shop/report/logs/
improved integration with the given file, the one for the request:
https://astelitgroup.crm-onebox.com/admin/shop/integrations/imap-3/control/
[file]8727[/file]
Good afternoon. You can find out the settings of the mail service from the administrator of this service or from the one who set it up. You need to know: - what ports are used for work; - whether TLS/SSL encryption is needed For our part, we can only guess how the mail service is configured.
You need to know:
