Incorrect graphic display of data on the dashboard
On the dashboard, in the graphical part of the data display, the graph does not correspond to the real data https://monosnap.com/file/rh1yXr6bfCEXHi1q9q8FqvhGEV7Hv7
KRI counts correctly https://logogroup.crm-onebox.com/admin/customorder/kpi/?filtermanagersid=&fi... -01&filtercdateto=&filterctimefrom=&filterctimeto=&filterdelivery=&filterpayment=&filterpriority=&workflowid[0]=41&statusid[0]=449&filterauthorid=&filterproject=&filterproductname=&filterproductid=&filtercode1c=&filterdatetofrom=&filterdatetoto=&filterdateplanfrom=&filterdateplanto=&filtertags=&filterorderemployerid=&filteremployerid[0]= &filterutm=&ok=1&searchLine= and the numbers match the data on the dashboard https://monosnap.com/file/RJZy7JGGTX7L7pCEsRdCfbtiiBV2CM
The graph shows values in the range from 2612500 to 3150000. I opened the CRI chart with a monthly breakdown - there were no such amounts in this period https://monosnap.com/file/rh1yXr6bfCEXHi1q9q8FqvhGEV7Hv7
Help fix it.
