Є rіven tsіn https://baza.cn.ua/admin/shop/price/4/edit/
In the new type = Vіdsotok nizhki
If robimo unloads on the outlet
Here https://baza.cn.ua/admin/auto/action/hour/edit/
box_auto_action_price_place_rozetka
That is indicated in the Fixed price \u003d tsey equal price and everything is correct
To put down the correct price
And from if robimo downloads to prom / PROM
box_auto_action_price_places_yml
I write the tag
Then in the new write no price like a socket
And write vіdsotok <oldprice>-110.0000</oldprice>
And it is guilty to write the price 599
Please correct
[file]12321[/file]
[file]12322[/file]
[file]12323[/file]
Є rіven tsіn https://baza.cn.ua/admin/shop/price/4/edit/ In the new type = Vіdsotok nizhki If robimo unloads on the outlet Here https://baza.cn.ua/admin/auto/action/hour/edit/ box_auto_action_price_place_rozetka That is indicated in the Fixed price \u003d tsey equal price and everything is correct To put down the correct price And from if robimo downloads to prom / PROM box_auto_action_price_places_yml I write the tag Then in the new write no price like a socket And write vіdsotok <oldprice>-110.0000</oldprice> And it is guilty to write the price 599 Please correct
https://baza.cn.ua/admin/shop/products/61907/edit/
you have -100 for the price level in your product - it transmits -100
Well, I wrote: In the new type \u003d Vіdsotok nizhki Tobto yakbi ti boov "Price" Also, everything is plugged into the socket correctly, so that the price is lower for each nationality
because this action unloads as the value of the specified price level, which is filled in the product card
Duck above you indicated that it unloads correctly - is it no longer correct?
