You need to somehow pull out information about the advertising campaign via SMS from the client and write it down in the box.
According to the idea here https://developers.facebook.com/docs/graph-api/reference/page/messages/ in objects you can pull out info. By the type of utm tags or some other information.
You can look at the example of this task https://hellom.1b.app/1026/ if there is any infa in objects that could be pulled out?
If there is info, how many hours will it take to implement the info entry in the field?
You need to somehow pull out information about the advertising campaign via SMS from the client and write it down in the box. According to the idea here https://developers.facebook.com/docs/graph-api/reference/page/messages/ in objects you can pull out info. By the type of utm tags or some other information. You can look at the example of this task https://hellom.1b.app/1026/ if there is any infa in objects that could be pulled out? If there is info, how many hours will it take to implement the info entry in the field?
The link to the photo, apparently, arrives in the push only if the contact clicked on the advertising post and wrote you something from the post or something similar. Usually it's just a message
Da Hong Pao OneBox production wrote: The link to the photo, apparently, arrives in the push only if the contact clicked on the advertising post and wrote you something from the post or something similar. Usually it's just a message
Where should the link to the photo fly to? In a comment?
Da Hong Pao
