Price recalculation does not work when placing a supplier order. For example, we provide cargo transportation services. Depending on the distance, weight and other parameters, the cost of transportation services varies. The program has created the nomenclature "Organization of Transportation and Administration". When it was selected, only the input cost changed. When saving, the final parts of the process were recalculated. As of today, the recalculation is not working.
https://onebox.constantagro.com.ua:44553/admin/customorder/postachannya/1436/edit/
We have a supplier service, its cost is constantly changing, in the process we indicate the input cost. When saving the process, the cost and the final part were recalculated, which became equal to the input cost.
But earlier it was recalculated, regardless of the cost that is indicated in the product card, if the order manually indicated the incoming cost. There cannot be an incredible amount of the same product, but with different input values.
The fields of the process product "Price without VAT", "Price without VAT", "Price with VAT", "Price with VAT" are not recalculated. They cannot be changed. It is possible to change only the "Input price" field.
https://onebox.constantagro.com.ua:44553/admin/shop/activity/?url=/admin/shop/workflow/9/procedure/10/ you can see from the history that you had an action when saving. which copies the Input price field to the Price field for process products. User "Lisenko Oleksandr Mikolayovich" 2021-04-21 20:30:14 removed this action.
