Нужно принимать и оплачивать платежи Fondy ?
Это можно настроить в последней вthcbb OneBox! Установить бесплатно последнюю версию!
Good afternoon
Faced this problem
When connecting Fondy, we enabled the ability to accept payments via personal account in payment methods
When trying to pay through personal account
we get this situation
redirects to the login page with an alert
"Access is denied!"
our CRM is located at https://www.labpdd.com
17.02.2021, 15:44
Hello.
Try it now.
If it doesn’t work, provide a link directly to the process you are trying to pay for and to the contact from which you entered the personal account
18.02.2021, 16:33
Good afternoon,
now redirects to this page https://www.labpdd.com/payment/fondy/
If you click on the "send request" button
We get an error
Link to BP https://labpdd.com/admin/customorder/order/?workflowid=15&searchLine=
Any contact can be used as the error will be repeated
19.02.2021, 11:16
Ivan Kolesnyk wrote:
We get an error
Unfortunately, I cannot say why this error occurred on the side of the payment service.
If you have such an opportunity - ask this question to the technical support of the service, I think they will look at the request ID what the problem was.
19.02.2021, 16:45
Welcome to know
one more question, (see screenshot) does this page always appear after pressing the pay button or is it also some kind of error?
19.02.2021, 17:02
The payment system requires form submission. By default it is implemented in a similar way.
You can make the form appear with a beautiful button under the payment method selection form inside the process - this will take 2 hours.
19.02.2021, 17:04
Ivan Kolesnyk
Client wrote:
Good afternoon,
We get an error
Good afternoon
We got this response from Fondy
We fix that you had an incorrectly formed signature. The signature is formed by applying the SHA1 function to a string consisting of the merchant's password (the payment key in the technical settings) and all parameters (mandatory of all parameters), concatenated to it in alphabetical order and separated by the vertical bar |
Also, we recommend that you read this documentation - https://docs.fondy.eu/en/docs/page/3/#chapter-3-5
[\quote]
23.02.2021, 11:39
We are on this documentation and form a signature.
Specify, perhaps it is also necessary to pass the server_callback_url and response_url parameters in the signature (which is not explicitly mentioned in the documentation) ?
23.02.2021, 13:55
server_callback_url and response_url are not involved in signing
23.02.2021, 14:58
Well, then we build everything as per the documentation.
Check if the password specified in the integration settings matches the one in the technical settings of the Fondy account.
I can, for a specific process (provide a link), indicate an example of generating a signature for further verification by Fondy.
23.02.2021, 15:03
If it's not difficult for me to show them something
BP examples:
https://labpdd.com/admin/customorder/order/1813/edit/
03.03 Service Order - https://labpdd.com/admin/shop/workflow/15/parameters/
23.02.2021, 15:09
Sent an example with real data to your mail vegaloki@gmail.com
23.02.2021, 17:23
Good evening
fondy's answer
For this integration method, you need to use this documentation - https://github.com/cloudipsp/php-sdk-v2 and the signature will be generated automatically
23.02.2021, 17:53
And what is wrong with a similar method of forming a signature - can they explain?
It makes no sense for us to "sew" the entire sdk into the product for this functionality
24.02.2021, 09:11
Good afternoon Maxim,
If possible, please write all the questions you need to ask FONDY
24.02.2021, 10:27
At the moment, there is only one question - what is wrong in the formation of the signature according to the example I provided?
24.02.2021, 12:08
FONDY's answer
Good afternoon
Please send the string you received with response_signature_string
24.02.2021, 12:40
this is the answer
this is how the string to generate the signature hash should look like
**********|2000|USD|1405299|2073|2073|http://labpdd.com/payment/fondy/success/|http://labpdd.com/payment/fondy/success...
13:11
operator profile
instead of * * * * - your Payment Key
24.02.2021, 14:12
interesting movie - sometimes they say it participates, sometimes it doesn’t
I'll add it now and try it, I'll write about the result
24.02.2021, 14:14
Thank you !
Ps and thanks for the present
24.02.2021, 14:21
