Good day! At the moment, on the current version of the system (MVP), it is possible to delete payments in bulk. To do this, go to the section "Actual payments" /admin/shop/finance/ .
- Use the slider below
https://prnt.sc/zp2xre and you will see a column with Checkboxes
https://prnt.sc/zp2zkk .
- By clicking on the checkbox in the table header, you select payments only from this page, but you also get an inscription within which you can select all filtered payments
https://prnt.sc/zp34g7,- Then you need to open the bulk changes panel in which there is an item Delete
https://prnt.sc/zp37tm
