Base currency of the skin
If there are data in the system (payments, processes, etc.) - this cannot be done just like that, because each entity has a conversion at the rate of the system currency relative to the hryvnia.
If you switch and convert all data in relation to dollar rates, it will take about 30 hours of refinement.
If the system was without data, we could change the currency even now.
Or, at your direction, we can change it even now, but then all the summarizing data in the system (financial balances, liabilities, etc.) will not be correct - and this, believe me, is quite critical.
29.01.2021, 11:25
just a little testy, and nothing has been done, change be kind
29.01.2021, 12:01
changed.
do not forget to change the exchange rates now relative to USD = 1 https://inter.crm-onebox.com/admin/shop/currency/
29.01.2021, 16:06
