Good afternoon! I am duplicating an earlier created task, in which none of the technical support answered. https://crm-onebox.com/ru/support/finances/5576-pomenyat-bazovuyu-valyutu/
1. To get an answer to the task in a short time (up to 2 days) - form your thoughts immediately with a description so that there are no comments in the task. Employees often respond quickly to new tasks where there are no answers. 2. Based on your request, I do not see that a currency change is required. If you need to rename KZT to Tenge, you can do it yourself in currencies https://leroom.crm-onebox.com/admin/shop/currency/
Good evening! Since just the same in the topic title and description, I wrote that you need to change the base currency to "Tenge". Since your default currency is "Ukrainian hryvnia".
If you want your tasks to be solved within a certain timeframe, you need to use paid technical support services https://crm-onebox.com/ru/prices/#support Otherwise, specific terms are not regulated. In this case, the task will be completed after you clarify all the nuances - I asked the last question here https://crm-onebox.com/ru/support/finances/5711-pomenyat-bazovuyu-valyutu/ We can only switch the currency for free, without any data conversion - is that okay?
dmitryi wrote:
When will the task be completed?
