Displaying budgets
Hello! There are three budgets created in Boxing, one of them is virtual. The virtual budget does not appear on the Budgets page. It can only be seen on the add budget page. How to customize its display on the Budgets page?
Hello. Please support with links. Where it is displayed and where it is not and what kind of budget are we talking about
11.11.2020, 13:53
https://bxx.as-service.com.ua/admin/shop/finance/buget/ - page Budgets, we see TWO budgets
If Add budget - three budgets are visible on the right, incl. virtual https://bxx.as-service.com.ua/admin/shop/finance/buget/6/list/ , it is also impossible to edit it
11.11.2020, 13:58
https://bxx.as-service.com.ua/admin/shop/finance/buget/ displays here only non-virtual budgets
11.11.2020, 14:24
Right. Where can I see virtual budgets?
11.11.2020, 14:43
Their list is there, on the page there is a sign. If there is information on a specific budget, then open for example "All operations" in the same plate and you will see something like this https://bxx.as-service.com.ua/admin/shop/finance/buget/6/list/
11.11.2020, 14:45
Those. Is it possible to display the virtual budget on the Budgets page (as well as non-virtual ones)?
11.11.2020, 14:50
only as a separate setup, it will take about an hour
11.11.2020, 14:51
Yes, very strange! Okay, but how do I delete or edit the virtual budget? I don't see this possibility
11.11.2020, 15:02
https://bxx.as-service.com.ua/admin/shop/finance/buget/6/ go to the budget, delete, edit, etc.
11.11.2020, 15:32
