Ignore virtual payments
How does the setting in Other work: Ignore virtual payments in the amounts of incoming/outgoing payments of a business process? That is, if the setting is turned off, we make a virtual payment in the process and in the Paid field we do not see the amount spent? Or does it affect liabilities? So far I don't see a difference with the setting turned on or off.
This checkbox allows you to create a payment that will affect the obligations, but will simply not be taken into account in the total amount of the wallet. Only and everything
05.10.2020, 13:14
Hello, this setting affects the values of the paymentSumIn paymentSumOut paymentremainder fields in the universal block and in some other formulas and blocks.
Try to display these fields in the universal block, make 1 virtual payment and the second regular one. Then you can see the difference.
05.10.2020, 13:19
a virtual payment with and without this checkbox updates obligations, and is not taken into account in the amount of finance. That is, this checkbox does not affect the one you specified.
05.10.2020, 13:40
checked, thanks.
05.10.2020, 13:44
