How to enable integration with a private bank
Good day.
Is there an instruction on how to connect the integration with the private?
Where to get data for zapenennaya fields?
Thank you
Andrew, good afternoon.
If you are asking about card accounts of individuals, Privat chipped away at this possibility last year https://1b.app/ua/forum/integrations-with-banks-and-payment-systems/16030-perest...
you can use Mono.
05.07.2023, 14:00
Ihor Susiak
you can use Mono.
Good day.
Thanks for the answer.
Does this also apply to FOP?
05.07.2023, 14:02
Integration with FOP works.
05.07.2023, 14:44
Ihor Susiak
I did not find instructions on how to connect to the fop
05.07.2023, 15:06
05.07.2023, 16:11
Ihor Susiak
try this instruction https://docs.google.com/document/d/1T7pFRMslBT2Pi9dsgXqSG7dKToJProbjy8IEr6weYM4
Thank you.
added the automatic action "Privat24 Autoclient Billing" and added the ID and Token, but nothing loaded.
I will try to add something else to the application itself
05.07.2023, 16:17
loads the action on the minute crown.
05.07.2023, 16:23
Andrew wrote:
Thank you.
It is also necessary to specify "Account numbers (to whom)"
06.07.2023, 16:42
Maksym Vadimovych Tyndyk
OneBox production wrote:
Andrew wrote:
Thank you.
And leave these fields empty? https://img.crm-onebox.com//media/5f/71/5f712a58e7b6ae0c6dc34abe53eea716.jpeg
06.07.2023, 17:02
In the automatic action once a minute "Privat24 Autoclient Statement of accounts" you need to add id and Token, account number and that's enough. There is no need to fill out anything in the private application
07.07.2023, 16:45
